Browse Forums DIY, Home Maintenance & Repair 1 Sep 16, 2008 10:21 am That part of the plasterboard wall used to have an aircon I suppose and the previous owner decided to replace it with a split-type system.
Anyway where the aircon used to be, he plugged the hole with a rectangular wood. BUT it is not properly aligned to the wall. Thus, at certain angle, you can see a shallow depression. It is probably 2 to 3mm depth at the lowest point. I thought of filling it (using light filler) but I'm not sure if this is the best way to go? Any thoughts? Thank you very much Re: tips on filling a shallow rectangular depression in the wall 5Sep 21, 2008 8:19 pm I'm not a pro but have done a fair bit fo plastering in the last few months.
Is the wall solid. ie NO movement at all in that section? If so then you could just plaster it. but you will need to do lots of coats to ensure it does not run or crack as it dries. Best method is to rip that bit out and redo it properly, but if it is solid, you cna get away with it. Is it cost effective to keep plastering all over it. Not really IMO. I used this guys web site to get me up to speed on things I should do. Steve http://www.how2plaster.com/ Re: consult some professional 7May 07, 2009 9:36 pm Lucysmith I think you should consult some professional only he/she can properly guide you Could you please offer some advice to this because it is the line of business you are in. Re: tips on filling a shallow rectangular depression in the wall 8May 08, 2009 4:51 pm If its a plaster board OR brick plastered wall with a timber in-fill you have dis-similar materials and will always have a hair crack no matter how good you fill it and sand it off. If you just want to bodgie it up, there are plenty of fillers on the market,. Have fun. Arfur Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4743 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31281 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17363 |
