Browse Forums DIY, Home Maintenance & Repair 1 Jan 26, 2019 2:38 pm Hi, I am not the handiest person and hoping for a bit of help before I dive right into it. Does anyone have good advice on how to repair an outdoor timber handrail that has large splinters. I have attached some photos. Do i cut the splinters out and fill the gaps or should I glue down the splinters. The handrail gets a lot of sun and is always exposed to the elements. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: large splinters - outdoor handrail 2Jan 26, 2019 5:18 pm capow Hi, I am not the handiest person and hoping for a bit of help before I dive right into it. Does anyone have good advice on how to repair an outdoor timber handrail that has large splinters. I have attached some photos. Do i cut the splinters out and fill the gaps or should I glue down the splinters. The handrail gets a lot of sun and is always exposed to the elements. Due to the run of the grain, you'd have to cut pretty deep to get that to stop splitting, and filling that hole would be tough, although not impossible. Alternatively, you could glue and bandage it and then see what it looks like in a few week time and then sand, patch and paint. However, personally I would get someone in to replace the entire handrail, top to bottom, with new quality timber. While you are in the mood for doing some maintenance, I'd be getting some decking oil or coating on those treads. They will eventually crack too, and replacing those stairs will be a several thousand dollar job. Re: large splinters - outdoor handrail 3Jan 26, 2019 6:32 pm arcadelt capow Hi, I am not the handiest person and hoping for a bit of help before I dive right into it. Does anyone have good advice on how to repair an outdoor timber handrail that has large splinters. I have attached some photos. Do i cut the splinters out and fill the gaps or should I glue down the splinters. The handrail gets a lot of sun and is always exposed to the elements. Due to the run of the grain, you'd have to cut pretty deep to get that to stop splitting, and filling that hole would be tough, although not impossible. Alternatively, you could glue and bandage it and then see what it looks like in a few week time and then sand, patch and paint. However, personally I would get someone in to replace the entire handrail, top to bottom, with new quality timber. While you are in the mood for doing some maintenance, I'd be getting some decking oil or coating on those treads. They will eventually crack too, and replacing those stairs will be a several thousand dollar job. Thanks for that. I was at Bunnings today getting decking oil for the treads. Would it need a proper sand first? For the railing I will get some quotes and see what it costs to have it properly replaced. Thanks for your help. large splinters - outdoor handrail 4Jan 26, 2019 8:41 pm capow Thanks for that. I was at Bunnings today getting decking oil for the treads. Would it need a proper sand first? You can just oil straight on the grey treads, but it will not change the colour back to how it once was. Nothing wrong with that as it may better match boards on the top landing. However, if you'd like the original colour back, then you can sand off the grey to the timber underneath. However, if you do sand and want to keep the painted boarder on each tread, repaint those and let that cure before you oil, as paint will not stick if the surface is oily. PS, Gravox cannot help you here consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6628 4 4492 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13724 |
