Browse Forums DIY, Home Maintenance & Repair 1 Jan 05, 2019 7:16 am Hello I need some advice, the brackets holding the blinds in place have come out of the ceiling causing the blinds to come crashing down... In order for me to repair it Do I need to putty the holes and then redrill a hole and fit with longer screws ? It seems this might have happened before as I see there are already plugs in the holes... I should replace those to right? Any particular products/putty etc I should be buying at bunnings? I have attached a couple of photos also. Thanks in advance.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brackets for a blinds fell out of Ceiling 3Jan 05, 2019 7:28 am Definitely should be fixed to a stud or frame. The spaghetti anchor that was used previously isn't great at the best of times. You may get away with a hollow wall anchor (search Bunnings) or my preference if you really have to is https://www.bunnings.com.au/mascim-45mm ... k_p2260466 Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 3283 Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1921 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29619 |
