Browse Forums DIY, Home Maintenance & Repair 1 Dec 29, 2018 3:26 pm Hi all I am.wanting to install two timber floating shelves in my kitchen, one above another. First one just above where the splashback tiles finish. It's only about 700mm.wide and I was keen to get one custom cut from a timber supplier . They give you two steel robs that are designed to go through timber studs or concrete/brick. My problem is that it's between a window frame and a wall return and there is only 1 stud roughly in the middle. There are about half width studs at either end – to do with the framing I guess. Any suggestions of how to attach these onto the wall? It's a brick veneer plaster wall. An.image can be seen here https://ibb.co/FYF0wh1 Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6140 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8183 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3002 |
