Browse Forums DIY, Home Maintenance & Repair 1 Dec 22, 2018 4:43 pm Hi, I have popped plasterboard to my outdoor studio and after much research on installing the plasterboard I realised that I made a mistake with installing it. My issue is i did not put the tapered edges together ( i missed that bit in the instructions I found online.) So what I have on one wall is a tapered edge and the cut side of plasterboard. My question is do I treat it as a butt joint and just fill as best as possible on the taperd side. Or is there another way I could look at this, any advice would be much appreciated. Nicole Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18200 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 |
