Browse Forums DIY, Home Maintenance & Repair 1 Sep 15, 2018 8:13 pm Hi guys I have a Dorf kitchen tap which I would like to remove the nozzle / aerator and replace with another one as shown in the picture. I have tried using spanner but it doesn’t grip nicely for me to make any progress. can this nozzle be removed? If so, how? Any advice much appreciated Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help removing tap nozzle / aerator 4Nov 29, 2018 9:10 pm Going on the picture it looks as if it is a female aerator and may screw off under the groove section in the photo. I usually use a thin bit of rubber like an outlet washers for more grip. Try with your hands but you may need to use a pair of multigrips over the rubber being very careful not to sctratch the chrome off. It could also be a style that needs a plastic key like tool to unscrew from the bottom. Try speaking to the plumbing supplies like Reece or Tradlink. They may have a spare one they can give you. that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7379 7 5136 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6714 |
