Browse Forums DIY, Home Maintenance & Repair 1 Sep 06, 2018 5:44 pm So on one side of my shed is a ditch where water has slowly rotted away the cement sheeting and I need a way to remedy it, do I just concrete it back up?? DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5416 |
