I need to remove the drain cover so I can clear the drain. The water is not running away and is flooding the balcony. Any ideas how to remove it please?
Browse Forums DIY, Home Maintenance & Repair 1 Jul 18, 2018 2:30 pm Re: How to remove the grill for a drain cover 2Sep 16, 2018 9:13 pm Have you done this yet? It’s the middle circle that needs to come out. Usually it is winded in. So twist it left to loosed and lift it. If it’s hard to shift try 2 screwdrivers or something you can use to help you twist it 2 10987 Excellent, thanks for the tip ... not in Sydney, but I might give the Dy Mark a try, cheers 2 1347 |
