Browse Forums DIY, Home Maintenance & Repair 1 Jul 08, 2018 7:19 pm Hello, I was inspecting an apartment close to the sea which I've fallen for, but saw some apparent rust marks on the ceiling metal trellis feature to the balcony. Took a photo of it - hoping to figure out if it's caused by long-term water leakage from pipes above the feature, or if the previous owner had (unintentionally) sprayed the ceiling with some corrosive liquid, or if it's just general poor quality of the feature rusting from the higher salt content in the air (being close to the sea). The marks appear quite randomly placed so it made me think it's not water leakage - but any thoughts? Thank you! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I agree with Althom but there also may be a problem with the terra cotta stormwater pipe discharging water in that areas as well. You can just see the top of the pipe at… 2 14890 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10591 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5827 |
