Browse Forums DIY, Home Maintenance & Repair Re: Is it possible for me to do this water leak job? 2Apr 09, 2018 11:21 am knhchris The issue that I am having is that when the water hits the wall, the water leaks from a tile 30cm away from the shower area. Any advice on either 1) how to fix Or 2) you must engage a plumber How do you know it is from that tile in the corner and not just leaking under the shower screen? Is it possible for me to do this water leak job? 4Apr 09, 2018 11:52 am knhchris I tested by putting the water on each tile and it seems to be that the leak is observed whenever water hits that corner. That seems a reasonable troubleshooting approach, but just be mindful that the water may take some time to travel behind the tiles. Be that as it may, you do not need a plumber as you do not have a problem with your plumbing - the problem is with the integrity of tiling (tiles, grout and/or glue). The waterproofing barrier behind the tiles should be sound, so water is probably leaking in behind the tile and running across the barrier to come out at a different point. If the leak is minor and you know roughly where it is coming from, you should always use silicone to seal the grout in that area (it is unlikely to be the tile itself unless it is cracked). If the leak is more significant you might need to get a waterproofer or tiler in to scrap out the old grout and then re-grout. You can do this yourself, but you want to be careful to not scratch the waterproof barrier when removing the grout as that will have worse consequences over time. Re: Is it possible for me to do this water leak job? 5Apr 09, 2018 12:42 pm Hi Arcadelt, Thank you for the info. Great, I will apply the silicone to seal and see how it goes! There aren't much leak as you have mentioned so I am hoping that this gets resolved after. Will update you Kind Regards, Re: Is it possible for me to do this water leak job? 6May 27, 2018 1:52 pm Hi, You can control the problem temporarily with some tips but for the permanent solution, i think you must reinstall the tiles. You can approach a home maintenance company like HomeGenie they are good in providing masonry services. Re: Is it possible for me to do this water leak job? 7Jul 18, 2018 8:55 am Hi all, Thank you for all your replies. I have applied a silicone as a temporary fix. It has been working so far. I definitely agree with getting a professional to do more permanent job! Will need to save some money for that If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5084 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17323 |
