Browse Forums DIY, Home Maintenance & Repair 1 Mar 10, 2018 7:55 am I have two roof windows in the kitchen. One of the windows is a leak path for the rain water. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think the reason why the water makes its way through the roof is that there are voids between the window frame in the roof and the sheets the roof is covered with. I have attached a few photos to show the voids. Would would be the best way to plug these voids? Cheers, Alexey Re: Water leak through the roof window 2Mar 10, 2018 8:29 am Hi AlexeyYakovlev Welcome to the forum Did you take photos when it was being installed? Check the manufacturer's installation manual Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17318 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18791 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 |
