Browse Forums DIY, Home Maintenance & Repair 1 Jan 31, 2018 8:21 pm Hi. I've looked for an answer here, and found a reference to Poultice Stain Remover from Aquamix. We are also trying sugar water, straight metho, and phosphoric acid cleaner (that just made it worse). Can anyone advise either a different cleaning solution or product?? Thanks. you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3790 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 9471 First time building. this triangular part (marked in red) behind my two bedrooms does not have external wall bec of Alfreco roof… 0 693 |
