Browse Forums DIY, Home Maintenance & Repair 1 Jan 17, 2018 5:19 pm Hi all, I recently changed the water filter for our fridge. All was fine for a couple of weeks and just randomly one of the ends came out of the filter and flooded the house . The water filter is a 1/4" push fitting on either side. Unsure how this occurred as I made sure to push the fitting as far as it could go and it is located in a cabinet which is hard to access so would not have been moved by anything. I've re-cut the pipes and installed again however very reluctant to turn the water back on until there is some sort of safeguard in place. Has anyone has any luck with any good water leak detection devices that could prevent this happening? I've heard mixed reviews. Any ideas on how I can secure the push fitting? Really do not trust it anymore. TIA! Re: Securing Water Filter Push Fitting/Water Leak Detection 2Jan 17, 2018 9:19 pm I'd be looking at stainless steel jubilee clips, or car fuel hose clips. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20297 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5104 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17411 |
