Browse Forums DIY, Home Maintenance & Repair 1 Jan 15, 2018 9:15 pm This sits just above the slab of my second story, but it is inside the ceiling space of my first floor, when there is long periods of rain it drips water out on to the gyprock ceiling causing water stains etc. Should it be here and what can I do to stop it dripping water? Any help appreciated Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 5027 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 4116 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 3368 |
