Browse Forums DIY, Home Maintenance & Repair 1 Sep 25, 2017 7:36 pm Can anyone tell me how I can fix moisture damaged chipboard? I have a wall unit, some of the base of which has expanded (it's in a dry area - the cat sprayed on it!!!). Pictures attached. I'm tossing up between a wood glue or builder's bog. Any steps to take would be helpful too - e.g. do I need to sand back first? do I need to put something heavy on it to ensure once the glue/bog is put on it sets level? I want to be able to paint over it afterwards too. Any help would be great Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Chipboard wall unit repair 2Sep 25, 2017 10:25 pm In short, you can’t. Because it is made under pressure in a factory situation, once MDF chipboard expands it looses integrity and replacement of that board is the only option. Can the wall unit be dismantled? BTW, the cat needs to be neutered. DIY, Home Maintenance & Repair Hi All, Hoping someone might be be to provide some advice on my ceiling that needs repair. Photos attached, but seems like the alcove (??) is pulling away. Thanks Thomas 0 6551 DIY, Home Maintenance & Repair The intent of that sort of clause is being misaaplied. its suposed to be used to avoid paying out for things liek when you decided to do a reno yourself and the… 3 5551 |
