Browse Forums DIY, Home Maintenance & Repair 1 Oct 21, 2017 5:35 pm We laid a brand new hardwood floor and hired a drum sander from Bunnings. We started at 40 grit, 60, 80 then 100. We then hired a rotary sander and used 120 discs on the bottom. We noticed at this point that we had chatter in the finish. How do we fix this CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17631 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18305 bec of more thickness and underlay i prefer laminate. also my builder covers laminate only. 2 2225 |
