Browse Forums DIY, Home Maintenance & Repair 1 Aug 12, 2017 4:20 pm I have a timber fence with lapped treated pine palings (i.e. no gaps) that I needs to paint both sides of. It is about 40m long and 2m high. I figure it’s going to be quickest to get a spray gun to paint it. I’ll probably end up doing a primer and two coats seeing the wood will soak up the paint on the first coat. I’m tossing up between purchasing the Dulux RapidFinish Spray Gun or the Wagner Flexio 580. Any comments on either of these products for my job or any other suggestions? Thanks Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 3808 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 11492 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 3784 |
