Browse Forums DIY, Home Maintenance & Repair Re: How to remove this top handle 4Aug 07, 2017 10:18 am paulstin At risk is (damaging) your pipes and assembly To avoid that I would recommend one of these plumbing handle puller Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6354 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9082 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 |
