Browse Forums DIY, Home Maintenance & Repair 1 Nov 29, 2006 10:01 pm I have a house with a curved wall. It is approx 2.5m radius. The existing fibro sheet needs to be replaced. I am trying to work out a sensible method to install a fibro (non-asbestos!) sheet to the curved surface. Has anyone ever come across a similar problem? Re: Bending Fibro Board into a curve. 2Dec 06, 2006 8:14 pm Have you tried emailing James Hardie or CSR??
Plenty of houses were built with curved walls in the 50's/60's/70's - they may be able to recommend a particular type of fibro or technique for installation Thanks for clarifying. Sorry I misunderstood your point 7 6998 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7094 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11838 |
