Hot water not available when very cold
I have a on-demand gas hot water service and have found that
when its quite cold in the mornings or late at night, i cant get any
hot water. If i wait until it warms up a little, hot water flows
through fine.
I have looked at the unit, and it is successfully sparking when hot
water is requested, but the flame never lights - my guess (and it is a
wild guess) is that the thin gas pipe for lighting the flame has got
blocked by some moisture which has frozen when its cold and clears
when it warms up a little.
Anyhoo - anyone got any suggestions on what i can do to allieviate
this issue? As you can imagine, not having a shower before work isnt
too nice.
Thanks for any help.
was hoping someone else had run into something similar.
Most gas hot water systems except for storage work on flow rates. I would suggest that you turn on your hot water tap only. Once the water comes through then add cold water. If you turn the cold tap on first than add hot water, sometimes the heater will not fire up the burners.
Most heaters require about 6/min to fire up.
If this doesnt work, it may be the power pack has gone on your heater especially if it is Bosch unit with no power cord attached to it
Regards
Shane
1
Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single…
21/01/2024
Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio…
16/04/2024
2
the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you…
