Browse Forums DIY, Home Maintenance & Repair Re: Running cables in ceiling 2May 07, 2017 8:47 am The only regulation you need to worry about is the one that requires this type of work to be carried out by qualified and licenced persons. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 2 6178 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20165 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10658 |
