Browse Forums DIY, Home Maintenance & Repair 1 Feb 28, 2017 2:50 pm I have a solar hot water system. I have a leaking solar non return valve at the hot water return pipe and want to replace it. Under AU law, am I allowed to remove existing one and refit new solar non return valve by myself without hiring a tradie ? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14825 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20661 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25073 |
