solar hot water
You stuff that up and it could be very costly to the solar array on your roof. Plus you'll have insurance issues if you try to claim water damage later.
Get a plumber for this one.
2
the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you…
6/09/2023
I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be…
11/01/2024
Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks…
