Browse Forums DIY, Home Maintenance & Repair 1 Nov 03, 2016 5:30 pm I have about 2 meters ( measured vertically ) of these cracks on my separate garage. My first question is how to temporary stop them from getting bigger till i get to the root of the problem I came across a site that showed a wall anchor ( plate ) that is attached over the cracks and a nut that can be manually tighten ( bring the cracks closer ) .. slowly. can someone point me to where i can find this ( websites would be the easiest ) or does someone have any suggestions cheers Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1922 DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1105 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17204 |
