Browse Forums DIY, Home Maintenance & Repair 1 Aug 06, 2008 9:39 pm Hi people, I have an old building that my grand father had willed me. I'm going to do a little remodeling and was curious as to which is usually done first. I would think the walls would be first so you don't take the chance of damaging the new floor but would like other opinions. Should you install new flooring or work on the wall repair first? Any helpful suggestions and advice would be greatly appreciated.
_______________ building an extension Re: What comes first, walls or floor? 2Aug 07, 2008 9:53 am How rude 24 hours without a welcome....so Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ .
Were doing small scale reno's at the moment, removing ceiling fans, painting etc....which will probably culminate in re-coating the timber floors. We're working from the top down, but because we living there we'll be going room by room. We'd love to see photos....cue....Paula....! mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: What comes first, walls or floor? 3Aug 07, 2008 9:56 am Hi and welcome to the fourm!!
I'd start from the top and work my way down. If you post photos, I'm sure we will be able to give more specific opinions - I mean advise Here's the link on how. (thanks TDL ) http://forum.homeone.com.au/viewtopic.php?t=3466 Paula Re: What comes first, walls or floor? 4Aug 07, 2008 9:59 am Paula I'd start from the top and work my way down. Clarification....were are talking about home renovation?...... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: What comes first, walls or floor? 5Aug 07, 2008 10:31 am DH used to work as a painter before moving into the steel industry and he said you always should do painting from the top down. Paint the ceiling first then the cornices then the walls then door frames and skirting boards last.
Do the floor after all the painting done. PS: I have re-read this carefully to make sure there is no smutty innuendo - you have to watch out for deviant types on here who can read double meanings into just about anything Re: What comes first, walls or floor? 6Aug 07, 2008 10:38 am to_do_list Paula I'd start from the top and work my way down. Clarification....were are talking about home renovation?...... Sorry I answered in the wrong forum - it was the answer to something else Only kidding I meant from the roof down! Paula Re: What comes first, walls or floor? 9Aug 17, 2008 5:59 am Quote: What if you need to sand & polish your floors. Would that take precedence over any painting? Floors last - because during the painting process ladders etc are being moved around so it is best to the floors last which will also remove any scratches, spills or splatter that may happen. Steve Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7302 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17527 |
