Browse Forums DIY, Home Maintenance & Repair 1 Aug 29, 2016 3:25 pm Hey Guys, I just need some help with what to do with an issue I have on my front wall. It is starting to show rusting through the render and paint on the corners of the wall. I can only believe its from the beading that was used by the old owners that is rusting under the render and now showing through the paint. Does anyone have any suggestions as to how to fix the issue? Paint over, use primer over the top or remove the beeding all together? Re: Rust on rendered wall from beeding 2Aug 29, 2016 4:38 pm For permanent fix you need to replace external rusting angles with stainless steel. Rust will be too difficult to control. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8315 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8693 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7067 |
