Browse Forums DIY, Home Maintenance & Repair 1 Aug 21, 2016 4:29 pm Hi All, Long time visitor of the forums and now first time posting - hoping some of you seasoned DIY'ers can give me some advice on a problem developing under the carpet of our home. Picture below shows how a floorboard beneath the carpet has started to collapse. I don't have any access to underneath the house to get a visual on what may be causing this. I am also expecting that other floorboards may develop this same problem, as the house is 100 yr old workers cottage style that we've purchased approx 6months ago. Have any of you seen something like this before? Any ideas on the possible cause, resolution, and cost? I appreciate the carpet will need to be pulled up for a more thorough investigation however before I do this I wanted to check on the general opinion here; as I won't be able to put the carpet back down without professional assistance. Thanks in advance! nxh Re: Collapsing floorboards under carpet 2Aug 21, 2016 4:30 pm Apologies the image didn't work - here's a link: http://imgur.com/a/b6l1Y Re: Collapsing floorboards under carpet 3Aug 22, 2016 9:28 pm If it just the one board I would suspect termites. Termites are weird creatures,just seem to eat one board in a floor,fixed many of them. If it was dampness it would probably be over a wider area. Re: Collapsing floorboards under carpet 4Aug 23, 2016 11:20 am Appreciate your reply OldChippy! Has anyone else seen something similar? Is it possible that the board had been weekend by previous termite damage perhaps many years ago, rather than recently live termites? The pest inspection we had before said "No active termites or previous termite damage or workings were found at the time of inspection." however they also go on to note "Access should be gained to the subfloor to allow a complete inspection of the property." Thanks! Re: Collapsing floorboards under carpet 5Aug 23, 2016 6:48 pm nxh Is it possible that the board had been weekend by previous termite damage perhaps many years ago, rather than recently live termites? Yes they could have used the board as a weekender, as a getaway from their weekday lodgings. Re: Collapsing floorboards under carpet 7Aug 30, 2016 8:33 am nxh Hi All, Long time visitor of the forums and now first time posting - hoping some of you seasoned DIY'ers can give me some advice on a problem developing under the carpet of our home. Picture below shows how a floorboard beneath the carpet has started to collapse. I don't have any access to underneath the house to get a visual on what may be causing this. I am also expecting that other floorboards may develop this same problem, as the house is 100 yr old workers cottage style that we've purchased approx 6months ago. Have any of you seen something like this before? Any ideas on the possible cause, resolution, and cost? I appreciate the carpet will need to be pulled up for a more thorough investigation however before I do this I wanted to check on the general opinion here; as I won't be able to put the carpet back down without professional assistance. Thanks in advance! nxh That picture really shows us nothing ( except your carpet ). You need to fold back the carpet in that area and take some closeups. Stewie Re: Collapsing floorboards under carpet 8Aug 30, 2016 12:01 pm It could be termite damage, borer damage or rot or in combination of the above. Invasive inspection is a must to determine the cause, the extent and assist in recommendation of remedy. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Collapsing floorboards under carpet 9Sep 06, 2016 5:35 pm Yep rip up the carpet and get an inspection done. Hi All New to the forum and looking for some advice, has anyone else renovated an old miners cottage in or around Ballarat and been able to identify the flooring? We… 0 8776 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 1278 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16159 |
