Browse Forums DIY, Home Maintenance & Repair 1 Jul 30, 2008 9:51 am Hey guys,
Not sure if any of you will be interested, but im currently selling my Glasweld Europe G-Force machine. It is a one step system that can remove light to medium depth scratches from glass, without using a grinding / sanding method (which can distort the glass) It uses a combination of heat, friction, and a chemical reaction to "Fuse" the glass back together - Anyway, if any of you want to check it out - its currently being bid on ebay. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=260268490921 All the best Cam (also posted in windows and doors) Re: Remove scratch marks in glass - Distortion free 2Jul 30, 2008 10:00 am I'm fascinated to understand the linkage between the product and your username! mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face… 2 1826 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11838 |
