Browse Forums DIY, Home Maintenance & Repair 1 May 05, 2016 12:33 am Hi, people. I need an advice, at least on where to go and whom to ask. My garage is located in the common underground carpark, in a corner, and on one side it frequently gets a bit (or more than a bit) flooded. The floor is concrete. In front of the garage door (in the common floor area) there is a drain, even a couple of them, but the problem is that the section that gets flooded (inside the garage) is on a slope, i.e. lower than the drain, so the water does not flow into the drain, but rather gets collected in that section. Immediately I can think of two options, both of which seem a bit extreme, if not impossible: - raising garage floor - drilling the floor on the flooding side to install some kind of pipe or drain underneath Thanks for any useful advice in advance Re: Flooding problem - common underground garage 2May 05, 2016 9:13 am Go and see the body corporate or strata managing agent and explain that the situation is not tolerable. If it is common property then they have to do something about it. How much lower from the front is it? Stewie Re: Flooding problem - common underground garage 3May 05, 2016 11:50 am Well, the drains are in the common area, but the garage itself (where the water collects) is not common. It's separated from the rest of the parking spots, garages and so on by the sliding door. It's lower not by much, but enough for the water not to flow out. If I help the water out and then push it a bit more with a broom, it flows into the drain (it obviously requires an effort and some of the water stays). The problem is that if I don't periodically clean it, it becomes smelly and slimy, and I have some props kept there, so I really want to keep the garage clean and dry. I'll try to get hold of strata, but what would I do if I had to take care of it myself? Re: Flooding problem - common underground garage 4May 05, 2016 6:32 pm Believe me it is a body corporate issue despite the water collecting in your garage. There is obviously a problem with both the floor level in your garage and the drain outside. I've had to deal with strata managers and body corporates over the years and they will probably try and palm you off however it is their responsibility to rectify the situation. Stewie Until you find the cause of the flooding you need to take action to mitigate potential damage to your home. Get automatic float pump and dig a pit then connect to power… 2 4845 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9196 Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3939 |
