Deck Footing Anchors
http://www.titanbuildingproducts.com/st ... &classid=1
Deck will sit rough 600mm from the ground seems like a good solution for some of the tighter spaces I have to work with and easier to drill into the ground because of the hard clay.
Most of the decks and house foundations we did were concrete footings and brick piers although these days a lot are small concrete pad and a stirrup or gal post like a Unipier http://www.unipier.com.au/ or a duragal post http://www.google.com.au/url?q=http://w ... kMPpJkgRaA
Stewie
Personally I wouldn't trust anything like that but I am an old school builder.
Stewie
Stewie
Thanks for the products. Not that I'm going to scrimp out but these options seem a bit overkill for a DIY application.
I just think that they are a cheap option. Not better , just cheap.
Stewie
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
27/11/2023
1
PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon
18/01/2024
I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. …
