Browse Forums DIY, Home Maintenance & Repair 1 Feb 26, 2016 11:43 am In a 6 year old house we have some cracking in the render. Each window sill typically has a crack through one of the mortar joins: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I don't know what type of render and paint finish was used, but this is what a chip out of the corner of the wall looks like up close ( the chip is about 2cm long) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There is some other staining on the wall, so I'm thinking to paint it again, but what's the best approach to fix the cracks? Re: Cracking in Render 2Feb 26, 2016 3:31 pm Has anyone inspected brickwork articulation joints? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cracking in Render 3Feb 26, 2016 8:41 pm I don't know if anyone's inspected them. Generally the brickwork on the front is divided up into reasonably small sections, with full-height openings for garage and front doors. There is a moderate amount of movement in the external paving though, so the ground is probably fairly reactive. 1 6601 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18005 |
