Browse Forums DIY, Home Maintenance & Repair 1 Jan 17, 2016 5:18 pm Hi, I had a leaking Tap where it screwed onto the pipe... no matter what i did i could not get it to stop dripping. Out of desperation I put some silicone sealant around the tread of the tap before i screwed it on... I know this wasn't the best solution but I was desperate. I turned the water on for a minuet then thought this wasn't a good solution. I removed the tap and got out all the silicone sealant, I have run water through all the pipes but I am worried some silicone sealant might have got into the water pipes and contaminated then.... the tap is in the laundry so we do not use it for drinking water... as I said I have run all cold water tapes for a few minuets to try and flush anything out.... Not sure what else to do. Re: leaking tap 2Jan 20, 2016 2:21 pm jamesrww . as I said I have run all cold water tapes for a few minuets to try and flush anything out.... Not sure what else to do. Only a few minuets? Well there is your problem, that's way too short. I'd run it for the length of a full symphony at a minimum. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 7 5139 |
