Browse Forums DIY, Home Maintenance & Repair 1 Dec 29, 2015 7:06 pm Hello. Can anyone tell me if the vertical piece of wood in the built-in wardrobe can be taken out? I am assuming it's not essential or load-bearing? We have taken out three doors, and want to open up the robe area. I have a photo, but don't know how to put it in the forum, sorry! Re: Built-in wardrobe question 3Jan 01, 2016 10:17 am Thanks for your answer:) The post actually sits next to upper shelf, not supporting the shelf. Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4988 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3112 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12935 |
