Treating rust on galvanised steel roof
Mostly surface rust surrounded by patches of original gal on the unrusted areas. So a combination of both rusty steel and galvanised steel.
This is my proposed paint system
- Wash and pressure clean, allow dry
- Apply rust converter – wait 24 hours
- Pressure clean again to neutralise acid
- Apply zinc phosphate metal primer (1-2 coats)
- Apply Dulux Roof and Trim top coat (1-2 coats)
So I'm using Ranex Rustbuster to treat the rusty areas. As a test patch I pressure cleaned, then washed with soap, rinsed and dried to remove any salt or oil that might affect the chemical reaction. As soon as it had dried thoroughly I applied a liberal amount of rust converter on a 2m test patch and left it for 24 hours. I've had mixed results.
Some of the rust has gone white (what it's meant to do). On much of the rest the red rust colour is still visible. There's also a white powdery coating all over the surface.
So I called Bondall who recommend that Rustbuster not be used on Galvanised surfaces. The white powder is actually the acid etching into the surrounding gal. Should I be concerned by this? If anything won't it better prepare the surface for priming?
Also am I correct in thinking that the rusted areas no longer have any gal, that's why they are rusting? Therefore shouldn't the Rustbuster work on the rusty parts? They suggested applying another coat to the areas that were still rusty, but shouldn't this stuff work almost instantly on light surface rust? It's not exactly cheap and I don't have enough of it (or the time) to apply two (or three) coats to the entire roof. What might be stopping it from working effectively? Could it be the galvanised surface? Any ideas?
Would love to hear any tips from those who have restored rusty gal roofs.
cheers
Google liquid rubber in qld and look at there videos just a thought.i have use it on a lot of roofs to repair from leaking when customers of mine dont have enough for a reroof
40yo gal roof is towards the end of its life.
Reason being, even if you treat what you can see, there will be plenty that you can't see, and because of its position, it is generally more severe.
Prepare for replacement if possible.
Sorry to be the bearer of bad news.
Stewie
It now comes in a single step formula so no priming needed.
The only drama with it is that it is not UV resistant, so I would suggest checking condition again in 12 months and potentially repainting if neccesary.
This is what I use for people wanting to buy time while they can plan for replacement.
Lightly brush the roof down with a wire brush, wash with water, and give 2 coats when dry.
The issue with trying to treat all the rust and get any longevity out of it is that you will have rust on the under sides of the roof, gutter, nails etc as well. So to to be sure of killing ALL rust, you would need to remove roof, gutters, screws/nails etc.
So keep it simple, rust guard will buy some time.
All the best with it bud.
1
You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would…
8/01/2024
4
if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush
7/03/2024
2
That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel
