Browse Forums DIY, Home Maintenance & Repair 1 Nov 19, 2015 12:24 pm Hi we have just bought a home that was built with Hebel Blocks and I want to attach a pull out clothes line to an outside wall. Can this be done with Hebel Blocks, if so what is the procedure. Thanks for any advice. Regards Daniel Re: Attaching to a Hebel Block wall 2Nov 19, 2015 3:18 pm The Hebel Technical Manual Part 5 PDF might help find a solution. http://hebeldocs.myspec.net.au/specify.php?&id=1996500117 Re: Attaching to a Hebel Block wall 3Nov 20, 2015 11:19 am Hi thanks for the link, I'll have a read. Cheers Daniel I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 9839 I've gone for pre-fab walls. I did it because I wanted to remove the idiot factor from the construction on site , control theft and reduce waste plus its supposed to be… 10 82712 Hebel 75mm floor: The glue added will do nothing, will not miraculously stick panel together. Often the panels get cracks in them from handling and if a joist is… 3 31765 |
