Browse Forums DIY, Home Maintenance & Repair 1 Sep 13, 2015 12:25 pm I've recently bought a 30 year old house, it has a wood combustion fireplace in the lounge (set in to a brick wall) and a number of the bricks have suffered smoke damage. We will replace the fireplace for next winter, but for now, I'm looking for advice around cleaning the smoke damage to the brickwork around the fireplace. Thanks Re: Cleaning smoke damaged bricks 2Sep 14, 2015 1:55 pm Wow tough and messy job. Only high pressure would clean this but the mess it will make is not worth it. You could try a high alkaline tile and grout cleaner. Apply, scrub then rinse rinse. Maybe even vinegar could work test first. Re: Cleaning smoke damaged bricks 3Sep 18, 2015 8:07 am As per what GP says above. A bugger of a job. I had a similar problem when I bought an old unit many years ago. Smoke stained bricks above the fireplace needed to be scrubbed before I rendered the wall. I used a big plastic sheet on the floor then used water and bleach to scrub with a scrubbing brush then sugar soap plus a few others I can't remember. Then just lots of water to rinse and leach the smoke and bleach/sugar soap etc from the bricks. I never got rid of it all but got the bricks clean enough to take the sand/cement render. A lot will depend on whether your bricks are the softer kind or a harder type. Stewie Re: Cleaning smoke damaged bricks 4Dec 09, 2015 4:02 pm Sorry for the bump - just a couple little suggestions. Products that I have found to work to some extent for cleaning bricks - vinegar, gatorade (any sugary drink maybe?) Hydrochloric acid (try other options first) and finally depending on the brick you may be able to sand the very top layer off. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2249 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4984 |
