Browse Forums DIY, Home Maintenance & Repair 1 Nov 05, 2015 8:44 am The drain valve on my water heater is dripping steadily (almost running). Is this quite straightforward to replace? Could someone walk me through what I need to do? I assume it dripping because a washer has gone rather than something more complex with the pressure on the rest of the unit. What's that name of this part? Doing a search of water heater valves on Bunnings doesn't show anything similar and if you can tell, this is new territory for me. Cheers guys Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Replacing water heater drain valve 2Nov 05, 2015 9:56 am Temperature Pressure Relief (TPR) valve, if I remember right. Turning off the taps to the hot water tank, and releasing the pressure before you unscrew it (perhaps leaving a hot tap on inside the house, and turning off the power to the hotwater system. Naturally any warranties will require it being done by a licenced plumber, but most people can do this themselves. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Replacing water heater drain valve 3Nov 05, 2015 10:59 pm Hi there. Please dont put a ptr valve in it as for starters you wont get it to fit. What you have there is a cold water relief valve.depending where you are as in state etc you may get away wuth out it. Other wise if you want to install one see here for a idea http://ezyfixplumbing.com/hot-water-pre ... ief-valve/. Will give you a guide of installing the new COLD WATER VALVE NOT HOT WATER. Thread tape uo new valve turn water off at the blue tap which by the way is incorrect tape as should be a non return valve. Anyway turn the tap of remove the pipes and unscrew the valve then just install new 1 same way Re: Replacing water heater drain valve 4Nov 05, 2015 11:17 pm Thanks traveln... you can see I ain't no plumber ! Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Replacing water heater drain valve 5Nov 05, 2015 11:24 pm Treveln has covered it pretty well. Just ask for a H50 1200kpa COLD relief valve from tradelink or reece. Will set you back around $60 or so My build with FHBD viewtopic.php?f=31&t=78344 Re: Replacing water heater drain valve 6Nov 06, 2015 10:51 am Let me know how you go with it. Main thing just turn the water off. You will loose bit of water out of the tank so depending hiw long takes you to remove old an install new. Dont have any other tap open when doing as that will allow air intonthe system and make the water gush out instead of gurgle out when you remove the valve Re: Replacing water heater drain valve 7Nov 06, 2015 5:58 pm I always fix these by just cleaning grit out from between the sealing rubber and its seat, thats all that ever goes wrong with these. For starters have you tried to open and close the valve rapidly many times in an attempt to clean it out? If that doesnt work, Take it apart. Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16860 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8489 |
