Browse Forums DIY, Home Maintenance & Repair 1 Oct 25, 2015 7:08 pm We have a weatherboard property which sits on a brick wall - about 1.5m high on one side (it is on a slope). Now there has been some movement over the years and there are cracks (in fact we have just had some underpinnig done). Question is what are the options for render products that would resist cracking? Re: Rendering - what product? 2Oct 25, 2015 11:47 pm Full Dulux Acratex texture coating system. 1. render with P400 renderwall (acrylic modified render) 2. Prime with acraprime green render sealer (enables you to paint soon after rendering) 3. Coat with Acratex trowel on render (suggest sand finish or coventry coarse) 4. finally coat with Acrashield membrane (bridge cracking of cracks up to 2mm and elongation properties of 40% of the coating width) This is the only system which will not break down and will not show cracks. Do not settle for anything less than this 4 step system or else you will simply get those cracks you are talking about. I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 29740 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4889 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7490 |
