Browse Forums DIY, Home Maintenance & Repair 1 Sep 15, 2015 9:36 pm My house is sitting on a slope site, and there is a trench around house which lead all the rain water to somewhere. But the water is going so slow, the basement is always so wet. I want to fix this, but not sure what kind of handyman should I go to. Plumber? or a Builder? Thanks Re: Rainwater drainage is going slow 2Sep 18, 2015 6:28 pm Your easiest and cheapest solution is to divert some downpipes to a water tank that is plumbed as a detention system. Inadequate stormwater drainage is a common problem and a regulatory disgrace these days. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater drainage is going slow 3Sep 20, 2015 10:39 am +1 to what SaveH2O has said. Divert some downpipes to a tank, and then you can dispose of that water at a later time, and further down the slope away from your house. Even if you simply use the water to drain somewhere else over a few days via a strategically located garden hose, the water isn't pooling up next to your house. I'm assuming your house is on the higher part of your land, rather than at the lowest part of your block. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19520 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8431 |
