Cleaning smoke damaged bricks
I had a similar problem when I bought an old unit many years ago. Smoke stained bricks above the fireplace needed to be scrubbed before I rendered the wall. I used a big plastic sheet on the floor then used water and bleach to scrub with a scrubbing brush then sugar soap plus a few others I can't remember. Then just lots of water to rinse and leach the smoke and bleach/sugar soap etc from the bricks. I never got rid of it all but got the bricks clean enough to take the sand/cement render.
A lot will depend on whether your bricks are the softer kind or a harder type.
Stewie
Products that I have found to work to some extent for cleaning bricks - vinegar, gatorade (any sugary drink maybe?) Hydrochloric acid (try other options first) and finally depending on the brick you may be able to sand the very top layer off.
2
It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow > ) Jokes aside, I can see one member that is cracked. I would find a…
20/06/2023
7
No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my…
