Browse Forums DIY, Home Maintenance & Repair 1 Sep 07, 2015 8:32 pm Hi All I just replaced one half of the facia on the eave along my garage. The replaced timber is approx 5mm shorter in height that the original, so I want to run a strip of packing timber along the top edge to keep the front edge of the roofing tiles consistent. What timber should I use? I was thinking primed H3 treated pine, but I can't find it in anything close to 5x45mm. Would a hardwood moulding be suitable? Looking for something durable/moisture resistant. Cheers Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10700 Hi everyone, Just wondering if anyone has switched from a small square tile insert or normal square waste to a strip drain at all, and if so did the plumber or diy-er… 0 13199 |
