Browse Forums DIY, Home Maintenance & Repair 1 Aug 13, 2015 8:08 pm I want to put a shelf on a wall that has a pocket sliding door - the middle of the 1.2m shelf will have a stud for me to secure the shelf onto, but the left & right ends of the shelf will be into plasterboard and behind it a pocket sliding door. I've drawn a diagram of the cross section: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Basically, anything longer than 30mm will protrude into the cavity too far and scratch the pocket door whenever it opens and closes. The plaster is 10mm and the gap between the frame and the door is around 20mm. All the plasterboard anchors I've seen are longer than 30mm and will scratch the door Anyone got any ideas on how I can secure the shelf to the wall on the ends that are not resting on a stud? Re: Short Plasterboard Anchor? 2Aug 13, 2015 8:25 pm use one of these. http://www.bunnings.com.au/ramset-nylon ... k_p2260973 1. screw it in as far as you can, pushing reasonably hard when you do so as to ensure you dont rip the plasterboard apart towards you whilst screwing it in 2 take it back out and cut it to length and screw it back in If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8297 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7865 |
