Browse Forums DIY, Home Maintenance & Repair 1 Aug 07, 2015 6:46 pm Hello, we are thinking of installing a led stripe on our patio, however is there a way to install this directly to a light source? Because i can see online that all led stripes come with trasformers, and thus i suppose they should be connected straight to plugs? Thanks! Re: Installing outdoor led strip 2Aug 12, 2015 9:25 am Yes, if you have access to a surface plug socket as you mentioned. Eg. these have become standard for LED lighting kits. Then it's just like plugging in a light to a power point/ GPO. No need for an electrician apart from the initial install of the plug socket. Re: Installing outdoor led strip 3Sep 04, 2015 9:57 am Yes, you should be able to easily connect your LED strip lighting to your patio by connecting them to plugs and then plugging it into the power supply through a normal outlet. Re: Installing outdoor led strip 4Sep 04, 2015 2:27 pm Adam.M Yes, if you have access to a surface plug socket as you mentioned. Eg. these have become standard for LED lighting kits. Then it's just like plugging in a light to a power point/ GPO. No need for an electrician apart from the initial install of the plug socket. This. Get a sparky to install a switch in the correct location and a GPO socket where the transformer will need to go. If you are replacing an existing outdoor light and using the same switch you only need the GPO socket installed in the right location and connected to the existing wiring. Hi everyone, Just wondering if anyone has switched from a small square tile insert or normal square waste to a strip drain at all, and if so did the plumber or diy-er… 0 13129 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 |
