Ceiling paint looks chalky & patchy
No nothing comes onto my hand just looks chalky and patchy. Thanks
I used to do paint inspections for a living but this has me stumped a bit.
Does the surface feel rougher than the other areas?
Yes it does feel rougher but the paint previously before I painted was perfect. After talking to my local hardware store they reckon this has happened because I had the heater on whilst painting hence the paint drying to quickly. If you look at the picture that patchy area is next to the heater vent. I am not convinced but I am going to give it another coat without the heater on and see what happens.
That's a high possibility. Give the rougher area a good sand first.
Never a good idea to paint ceilings with heaters on or even air conditioners in the sumner.
Hope all goes well
Will give it a light sand on the weekend and paint over the patchy part with the same paint and same roller. If that doesn't work then I am going to change paint and roller and paint the whole ceiling again with no heater on. I am from Australia it's winter here and freezing in the mornings about 1 degrees hence why I had the heater on.
but are you sure you dont have this problem everywhere but just can't see it unless there is a window behind it shining light on it?
I can see a distinctive roller pattern there, indicative of either
not enough paint on the roller,
poor quality roller tray used, (needs nice deep ripples on the tray part)
trying to spread the paint to far (nto being generous enough)
When I did the 3rd and 4th coats I put heaps of paint on the roller to try to cover it up but made no difference.
so the problem is not in the substrate, so rule that out and not due to heating, so rule that out as well.
please do not take offence, but this is typically seen when a roller is rushed across the surface.
The different sheen levels are most often the result of overworking the paint.
different areas of the paint are thicker than others, and the thicker parts dry slower than the thinner parts. so when you run your roller over it to remove the roller lines, it picks up up tacked thin parts and gives them a rough texture.
Go back and try it again with a 12mm nap synthetic/lambswool blend 230 mm (not 270) and do it very slowly in no more than 2 passes. one pass of the roller to apply the paint, and one pass to level it out.
one roller application should cover 2 lineal metres by one roller width, then reload roller.
give that a shot in that area and see if you can get a uniform texture.
I then tried another room my outdoor patio ceiling came out perfect no lines patches or anything.
I am convinced there is something wrong with that room. Because the paint was perfect before I am starting to think I damaged the ceiling when I did the very first coat with the heater on paint dried too quickly and it has made it rough. Any ideas recommendations?
last resort, but that is the most likely culprit if you are certain you have eliminated application problems.
Hi Everyone, Ripped up the carpet and the surface below gas come loose and you can see the slab below. The material breaking away looks and feels like crumbling cement.…
29/09/2023
6
Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same?
