Browse Forums DIY, Home Maintenance & Repair 1 Apr 09, 2015 9:40 am Hi Guys , I am looking for a solution to repair some water damaged chipboard , a cost effective solution that's not going to cost me thousands as i will be looking at a floor covering over like vinyl or clip flooring. The board is used for flooring externally I know this is not ideal but its how i bought it but I'm looking to sell . Any ideas or previous experience would be greatly appreciated . thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: HELP Repairing water damaged chipboard 2May 21, 2015 2:59 pm Vinyl flooring is durable but fades with exposure to sunlight and on extreme temperatures, floors may get damaged. Hence, vinyl flooring is not recommended for outdoor uses. Better go for clip flooring. Re: HELP Repairing water damaged chipboard 3May 27, 2015 10:15 pm that chipboard is inside not outside right??? Just bog it up with 2k builders bog! Re: HELP Repairing water damaged chipboard 4May 28, 2015 7:31 am I can't believe they used chipboard outside for flooring. Is it different to the stuff they use inside ? Was it treated for weather somehow ? Just curious. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2242 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14142 4 10892 |
