Browse Forums DIY, Home Maintenance & Repair 1 Apr 06, 2015 2:19 pm Hi again, This time I am trying to fix my steps on our home where a steel railing is attached to the brick/cement steps. As they are about 40yrs old, from lots of use it has cracked through the cement layer on top. What is the best way to repair this? 1) Should I use a screw driver and hammer drill to clean-up the area first so that new mortar will bond to it? 2) What kind of render/mortar/cement mix should I use to patch this up? I've only got a bunnings nearby. Once patched, I plan to repaint the top in a cream colour. Thank you for your help and suggestions! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to repair cracked cement/brick steps? Pics attached. 2May 14, 2015 11:58 am You can use non shrink grout. Install some sort of form board or barrier to keep the grout in place and in shape as it cures. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: How to repair cracked cement/brick steps? Pics attached. 3May 14, 2015 2:53 pm If you just try and patch with concrete its likely to fail quickly. I would be drilling 2 -3 holes in the good concrete and setting chemset anchors with the bolt head well out into the repair area. Make sure you get a bonding agent to paint on the original concrete and follow the manufacturers instructions. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to repair cracked cement/brick steps? Pics attached. 4May 16, 2015 9:32 pm Only problem is, that the concrete has cracked because the steel has rusted. The rust then expands causing the concrete to crack. If you don't stop the steel from rusting the repair will crack again. You really need to use a rust converter then cold galv to prevent the rust, then patch the concrete. All that will be hard to do with the rail in situ. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3334 DIY, Home Maintenance & Repair Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want… 0 8752 |
