Browse Forums DIY, Home Maintenance & Repair Re: Brick wall dissolving! Help! 21Apr 06, 2015 2:08 pm Thanks for all your comments and help guys. I'm not sure that I will be able to completely stop it, but I will try to slow down the effects. First on the list is to fix up and re-locate the retic sprinklers and then i'll try a sealer. If it doesnt help then I'll just go to step 2 - remove the brick and replace. Thanks! can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4468 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7942 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10914 |
