Browse Forums DIY, Home Maintenance & Repair 1 Jun 15, 2008 11:03 am So some mongrel idiot decides our brick retaining wall would be a nice spot for him to advertise his atrocious handwriting skills, leaving his 'tag' in yellow spraypaint.....
Now I've got plenty of time to see the artistic value in LEGAL graffiti, and it can make the concrete jungle look a bit more humane, but why the hell to these a-holes need to deface private property with a simple 3 letter patterned tag that looks disgusting? So my question is.... 1, How can is successfully remove it from the bricks with a minimal amount of residual staining. I was going to try thinners, but that will probably only wash it deeper into the bricks, and spread the stain. 2. Are there any products that won't kill the grass & surrounding gardens when washed off the wall? Rendering the wall is out of the question - there's way too much of it, and the bricks match the house. The other problem will be the 'blank canvas' invitation once rendered....... Having a signwriter in the family, I know all about Graffiti-Clear & other prevention coatings, which we have on the front part of our fence, but it's too late for the bricks. Re: Graffiti removal from brick wall...... 3Jun 15, 2008 12:24 pm Ring the professionals and see how much they charge. Might be easier.
Graffiti-Busters and the like - might not be too expensive. Our office gets tagged every now and then - but the coucil has retirees with paint rollers who paint over it within days and they do it for free Trick is get rid of it quickly - that's the best deterrent. Re: Graffiti removal from brick wall...... 4Jun 17, 2008 8:49 am The best thing you can only do is have a prof come out and do it, we acid wash and re paint but once that is done you will have to seal it that way if it happens again you can remove it yourself with a garden hose.
Craig DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10242 |
