Browse Forums DIY, Home Maintenance & Repair 1 Nov 22, 2014 5:26 pm Hi all, After some advice please: Our pergola has a plasterboard ceiling and we get a few hairline cracks which presumably results from movement on windy days and temperature fluctuations. I'm in the process of fixing the cracks but I'm looking for advice on what paint to use when done. I'm after something that has a bit of flexibility to it which might help reduce further cracking. My main requirement, apart from flexibility, is that when applied it dries smooth like normal ceiling paint. I found the below in the UK but can't find it here but sounds like the type of thing I'm after. http://www.polycell.co.uk/product/polyc ... e-ceilings Appreciate any advice. Cheers Re: What Paint to Use 2Dec 05, 2014 6:20 pm You could try wattyl granoroll. It is generally used for render but has a 300micron film build up and the final texture is reasonably smooth. It has great flexibility and can bridge small cracks. [Edit: Advertising links removed by moderator] That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17857 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8310 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17538 |
