Browse Forums DIY, Home Maintenance & Repair 1 Nov 21, 2014 12:06 pm I need to plug some screw holes in a verandah clad with second hand colorbond (classic cream on top/shale grey underneath). Has anyone done this successfully - would welcome suggestions as to what to use to both withstand the weather and also disguise the fact that it is recycled tin. Re: Plug screw holes second hand colorbond 3Jan 30, 2015 12:40 pm Aren't there little plugs for this ? Re: Plug screw holes second hand colorbond 4Jan 31, 2015 12:29 am Pop rivets with a small dab of silicon applied afterwards for waterproofing would be the best bet visually wise. If the sheets are not exposed underneath you could just put regular roofing screws in the holes, they will hold. Re: Plug screw holes second hand colorbond 5Feb 15, 2015 1:10 am Use roofing silicon Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Hi team, Im looking for a second hand sd4b monitor preferably white. 0 8920 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8301 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7075 |
